I have done some searching and think I know what 'maybe' happening, but wanted to make a post and get your opinions as well.
I have a 2k svt w/40k on the clock. Over the past 2-3 weeks the car has developed a sort of hesitation when I drop the hammer. If I run at 3/4 throttle everythings is fine, as soon as I go to WOT the car starts to slow down, almost as if I have hit the fuel cut off, but I could be anywhere in the rpms and it will do the same.
Now I thought that since I was still running on the original plugs that they could be ready for a change. Did that, helped a little (very little) but the hesitation is still there.
OK, I still have the original fuel filter - changed that and it made no difference.
At this point I really don't know for sure what may be causing the problem, I am leaning towards the feul pump - what do you think?
*Remember this is on a returnless and only at WOT
