I did a quick search, and didn't find anything I tought was relevant, so here's my problem. From time to time, I will have trouble with my csvt not wanting to idle after sitting overnight in the cold. The car will start right up, but I must keep my foot on the gas or it will stall. After a few minutes, the engine will make a weird fog horn sound, and then will idle perfectly. This has happened three times in the past 6 weeks and it's always the same.
Thanks in advance,
Lee Alvarez
I
I
IAC (idle air control) valve. near firewall, next to coil pack. much posting about this if you search under IAC. I had a similar problem except for the noise, and was able to fix temporarily by smacking the top of the valve with a snowbrush. Part is about $50.00, and should be replaced. some people have tried to clean it, but that doesn't seem to last very long.
contours, deloreans & fiats, oh my!
I am having similiar problems with my new 2000 CSVT. It is called moosing and apparently very common on the Contour V-6. Go to FAQ section under common problems:noises and it describes the fix.The new parts will run about $120.00.
"Eagles may soar high, but weasels don't get sucked into jet engines."
