Ok, I've had my '00 SVT for 3 months, and Ive put 5k on it. it is currently at 40k The last two oil changes I've put in 10w30 mobil 1. (just on instinct because thats the weight I used in my old car) But I was wondering if 5w30 would be best. Please give me info on engin life, wear etc...
2000 SVT contour Black w/tan int. http://www2.gvsu.edu/~hafnerb/11h/car.jpg
#1633/2150 born 11/22/99
-Mirko Racing Front Splitter
-Meg's 3 1/2" slick tips
-Resonator Removed
-LED turn signals, brakelights
-fog light fix + 55w bulbs
-KKM cold air intake
-Ford racing blue 9mm wires
-MANY mods to come shortly!
1
1
5w30 because that's what the manual says and also what many people on here have said.
99 SVT Contour
02 Protege5
V
V
Factory recommends 5/30 - can't think of any benefit to using something else.
O
O
5w30 = cool
10w30 = :rolleyes:
I've been using 10W-30, but next oil change will be 5W-30. By the way, if an oil changing place says they use Mobil 1 Synthetic, what kind are they using?? I only want to use Tri-Synthetic, but I think there are other types of Mobil 1 Synthetic out there, right??
2000 Contour 2.5L ATX (Medium Steel Blue)
Items for Sale
  • SVT Indiglo Guages (NEW)
  • Traction Control/Rear Defrost Switch (NEW)
  • V6 Speedometer/Guage Cluster w/ Tach (51k miles)
FWIW, the rest of the car will likely fall apart before the engine needs a rebuild.
Just use what the manual says.
Brinn Riley
Melbourne, FL
'00 Black/Tan SVT Contour #560
Q
qaz Offline
Q
The shop manual for the '95 Contour says that either 5W-30 or 10W-30 is OK.
I think the user's manual says that 5W-30 is "preferred", but that may be more due to to fuel economy considerations.
Ford is specifying 5W-30 for all engines made since 1989 (more recently they started specifying 5W-20 for some).
Unknown is why the 1989 cut-off date, since I'm not aware of any changes between the 1988 and 1989
Mustang 5.0 engine, for example, that would make the 1989 more suited for 5W-30. The users manual for the 1988 only recommends 5W-30 in cold temperatures, 10W-30 otherwise.
I guess the bottom line is use 5W-30 if you can, but if it's sold out or something using 10W-30 isn't going to break anything.
Brian
E
E
Yeah, when your engine blows, and you tell 'em you use 10W-30.. in you last model Contique, Will they still warrant it???
Prolly''' but then again, maybe NOT!!!
Use the 5W-30
NoT 10W-30
NOT 5W-40
NOT 10W-40
NOT old chicken grease with a gasoline thinner..
One beat'99 Tropic Green SVT
Oil weight primer:
What the heck does 5W-30 or 10W-30 mean. The first part 5W or 10W is the cold weight. So a 5W oil is flows better at colder temp than does a 10W oil. The 30 is essentially the viscosity at a specific operating temperature.
In the summer time, I would be more comfortable with a 10W-30, especially if it is a traditional (non-synthetic oil). Why? Because there are fewer viscosity index improvers in the 10W-30 oil. There is less spread between the two weights. For a synthetic, this is not as much of an issue, but still an issue to some extent.
Viscosity, or a measure of a fluids resistance to flow is improved by these VI. However, these additives do nothing to actually lubricate the parts that spin and rub in your engine.
(Which is why I prefer a synthetic oil, fewer additives to make the lubricant behave, flow and resist acids, relative to conventional oils.)
So I think you would be fine with either a 5W30 or a 10W30 oil. If I were not using a synthetic, I would use a 10W30 in the summer and a 5W30 in the winter.
FWIW,
TB
Tony Boner
O
O
That's what I used to use in my '74 Duster. laugh
laugh
