Posts: 1,247 |
When I got some gas tonight, I think I filled it up becuase the pump automatically shut off. When I got back into my car it read 3/4 tank and before I filled up it read a little bit less than 1/4 tank. I got back outta my cart and it kept stopping and stopping. So, how do I know that the gauge is bad?? Any tests that I can do?? Any help is appreciated
Irfan Rahim
irfman2000@yahoo.com
2006 Blue Nissan Sentra SE-R Spec V
Former owner of a silver 2000 Contour SE Sport ATX
Posts: 2,408 |
The gauge rarely acts up without the other gauges acting up too.
The sending unit is usually the problem.
Make sure it actually is full first, a bad filler neck flap or some stations pumps will do this.
Posts: 1,247 |
Well, the auto shut off thing didnt activate until I got close to 10.00 which I did barely. So, is there anyway that I can test the sending unit??
Irfan Rahim
Posts: 151 |
Posts: 2,408 |
Originally posted by 2KSESport: Well, the auto shut off thing didnt activate until I got close to 10.00 which I did barely. So, is there anyway that I can test the sending unit??
The wires hook into the black box I believe. If you took it out it should be easy, output goes from 1-5 volts over float travel AKIK.
Posts: 2,408 |
Dude, don't you have anything better to do.
Posts: 1,521 |
Sounds like the flapper valve problem, which has a recall.
Chris G.
~ 98 Mystique LS ATX
Posts: 1,459 |
Yeah, that's what I was thinking. The auto-fill is kicking off too soon.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
