projectSHO89, Sorry I didn't write what was in your quote, but I will be using your information to test for that this weekend. I am a complete TOOL when it comes to electricity so calling in for reinforcements on the Volt/Ohm meter.
Question though, when I first pulled the codes using the Jumper Method (paper clip between pins) The first thing it does is cycle through first the low fan and then the high fan, and I am SURE that it did both.
Something may have happened between the first code reading and now so I will check again.... Best to rule everything out and it is not like THIS is as hard as changing the stupid PCV valve.. Really did elves put these cars together because my hands are still sore (from all the contortion, minds out of the gutter folks
TBone...669
