Now I can only comment on the V6 cars, but I'm quite certain the the alignment procedure is the same for both. I had my transaxle out last year for a rebuild c/w LSD install. Due to the very explicit directions in the Ford Service Manual, I borrowed the drivetrain alignment tool from my local Ford Service Manager (thanks!) so that the drivetrain could be aligned properly. I fooled around with it, set it up, and returned the tool. Now there was an increase in vibration plus I didn't like the way the transaxle bolted up to the rear lower mount.
In the meantime I ran into an ex Ford mechanic buddy. I asked him about aligning the drivetrain-was it necessary? His reply-If not done properly for a FWD car, there will be excess vibrations. This confirmed what I thought. I went back to the dealer, reborrowed the tool and did it right this time. Result-vibrations gone.
If you remove or loosen ANY of the 2 uppers or the rear lower mount, the drivetrain MUST be realigned. Don't let anyone tell you otherwise. The Ford manual is very specific-all text is highlighted in upper case. If you don't use the correct procedure & tool it's hit and miss, and you'll most likely miss!
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
