Maybe you need to clean the contacts for the bulbs? try using an eraser on both the bulb and the socket. Do not touch the contacts with your hands (natural oils prevent a good electrical circuit). If that doesn't work, get a voltmeter and verify that the socket is powered when your headlights are on.
good luck
-- Barry Wolf 1996 Contour SE MTX Midnight Red, Parchment leather Brakes: Bendix OEM size discs, Carbon Metallic Pads, Parking Brake TSB kit Engine: New IAC valve, new EGR valve, new cat, new water pump, moose fix kit, K&N drop in filter Tranny: Redline ATF + Ford Friction modifier Interior: Pioneer CD receiver, Pioneer speakers, Ford RS shift knob, Ford vinyl floor mats (great purchase!) Handling: E1 SVT Rims, Yoko AVS-I 205/55ZR16 (like butter) meats Other: High beam bulbs in low beam position, new trunk vent Other problems: leaky PS pump - fixed with 2 oz stop leak, 1 quart oil use per 2K miles Mileage: 62K (August 2002)
