#67720 08/03/02 07:20 PM
Hi, I got the codes: P0153 and P1151,
And they are from the B2 S1 sensor, they want to charge me 200 to change it!!, could you tell me where is located thi sensor?,
and could I change it myself?
Any special tool?
Tanks guys,
1998 Contour
V6 2.5L ATX
#67721 08/04/02 02:47 AM
P0153=Upstream Heated Oxygen Sensor (HO2S 21) circuit slow response (Bank #2).
P1151=Lack of upstream Heated Oxygen Sensor (HO2S 21) switch, sensor indicates lean (Bank #2).
B2 must be bank #2.
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
#67722 08/05/02 01:55 PM
I suppoused it was from bank 2, I just have the doubt of where in the car is the bank 2,
I know that there are 4 sensors, and I do not want to replace one that is working fine,
Additionally, Are the three sensor the same?,
If I bought it I just buy an oxygen sensor for contour 98 duratec? or OD I have to specify which one?
TNX
1998 Contour
V6 2.5L ATX
#67723 08/05/02 03:28 PM
I know that there are 4 sensors, and I do not want to replace one that is working fine...
The following is from http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=3;t=006069
Last but not least, it is worth noting there are actually four sensors: upstream and downstream for each of the two cylinder banks. They are called HO2Sxy, where x indicated the cylinder bank number (bank 1 is closer to the firewall), and y indicates upstream (1) or downstream (2). HO2S11 seems to be the most frequently-mentioned of them all (I replaced mine last year; there's a wealth of info available via Search).
Additionally, Are the three sensor the same?, If I bought it I just buy an oxygen sensor for contour 98 duratec? or do I have to specify which one?
I believe that the front two sensors are a little different than the back two.
I got the following from http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic&f=3&t=008139&p=
To make sure you've got the right O2 sensor before you leave the store, the lower one's have a round connector and the upper is a sqaure connector.
You can go to http://www.boschusa.com/AutoParts/PartFinder/PartFinder.asp for info on Bosch oxygen sensors.
Automatic
75,000 miles
#67724 08/05/02 06:03 PM
H
H
Originally posted by G Pappas:
..I believe that the front two sensors are a little different than the back two.
Perhaps ambiguous. Upstream (front) are before catalytic in manifold, downstream (back) are after catalytic in manifold.
The sensor of concern is on the exhaust manifold behind rad and to the right of oil filter. It is possible to change without an O2 sensor socket by using an open end wrench.
stock CD on LS, cass on LX
4 wheel discs on LX only
#67725 08/05/02 06:27 PM
How much should I paid for this sensor, ( I saw one in $67 in napaonline)
Souhld it be motorcraft, bosh, is it the same use any brand?
Can I replace the sensor from the top?, or do I need a ramp?
TNX
1998 Contour
V6 2.5L ATX
#67726 08/05/02 06:28 PM
TNX
Any Picture of the location of the sensor??
1998 Contour
V6 2.5L ATX
#67727 08/05/02 08:34 PM
[b]How much should I paid for this sensor, ( I saw one in $67 in napaonline)
TNX
Any Picture of the location of the sensor??[/b]
Any one??? please
1998 Contour
V6 2.5L ATX
#67728 08/05/02 09:11 PM
How much should I paid for this sensor, ( I saw one in $67 in napaonline)?
I believe that you can find them for ~ $50-60 at the low end.
Automatic
75,000 miles
#67729 08/05/02 09:30 PM
[b]Should it be motorcraft, bosh, is it the same use any brand?
TNX
TNx, and what about a picture?,
can I replace without a ramp?
1998 Contour
V6 2.5L ATX
