#807200 11/27/03 11:52 PM
Where do you mount this thing? I was thinking either under the battery, or between the windshield washer and coolant resovoirs. Also, how do you route the hoses? It looks like one hose should go from the metal tube on the UIM to the separator and the other tube from the separator to the pcv valve. Lastly, which hose goes to the top of the separator and which hose goes to the bottom of the separator? Thanks.
1998 SVT
The easiest place is right beside the brake fluid reservoir(sp?). The hose from the pcv valve goes to the bottom conection of the separator. The hose going to the intake should connect to the top of the separator.
"...first he's gonna s*!t, then he's gonna kill us." 1999 Contour SVT Retrojunk.com
Sounds good. Thanks for your help!!
1998 SVT
