A few days ago I noticed that my 1995 Mystique (104K) started stalling on a semi-regular basis. When I sit at a light or just stop, the idle fluctuates a bit and then just stalls. The car starts up right away and drives fine. What could this be? Fuel filter? Fuel pump?
As far as I know, the plugs/wires have never been changed, so perhaps it's time for a tuneup.
The idle in my car use to jump around at stop lights and signs too... I changed my O2 sensors and it hasn't done it since... Could also be the TB needs to be cleaned...
~*TJ*~ 97 GL Sport Zetec
~*RIP*~Connie~*1/21/02*
~*Mods*~ E0 SVT Rims~205/55R16 Goodyear American Eagles~
~*Mods to come*~ H&R springs~Konis~Coilovers~17x7 Millie Miglia Avia~215/45R17 S-03's~SVT body kit~98+ OE Spoiler~CAI~Brullen Cat-Back~Turbo (or 2):)~
More to come
I have a similar problem with my contour. I've noticed it only when running the A/C on very hot days. It has stalled as I roll to a stop about half a dozen time. Alarmingly, it also stalled as I was downshifting (not fast enough, it seems) before a slow (~20 mph) corner with traffic behind me. luckily, I was able to get it restarted before I got rear ended. I haven't had a chance to replace the O2 sensor yet, and I'm sure my TB is very dirty - I rev the engine to within 500 rpm of redline daily. My car has 62K miles.
Barry Wolf
1996 Contour SE MTX Midnight Red, Parchment leather
Brakes: Bendix OEM size discs, Carbon Metallic Pads, Parking Brake TSB kit
Engine: New IAC valve, new EGR valve, new cat, new water pump, moose fix kit, K&N drop in filter
Tranny: Redline ATF + Ford Friction modifier
Interior: Pioneer CD receiver, Pioneer speakers, Ford RS shift knob, Ford vinyl floor mats (great purchase!)
Handling: E1 SVT Rims, Yoko AVS-I 205/55ZR16 (like butter) meats
Other: High beam bulbs in low beam position, new trunk vent
Other problems: leaky PS pump - fixed with 2 oz stop leak, 1 quart oil use per 2K miles
Mileage: 62K (August 2002)
I may be comparing apples to oranges here, but I had a '94 Probe with 130K on it that did the same thing. Turned out that it was the IAC motor, not the O2 sensor. Since Mazda parts are ludicrously priced, I traded it in for my 'tour, which pulls the same crap at 60K... on rare occasions, fortunately.
Black/tan early '98 Contour SE Sport; V6, MTX, loaded
Kenwood KDC 316S CD deck; aux. dome light mod; trunk popper spring; resonator bypass; hood strut mod; SVT grille; Continental tires
Mom also has black/tan '98 Mystique LS; V6, ATX, Alpine CD deck
The other people I've spoken to have mentioned the O2 sensor, so perhaps that's it. I dropped it off at my mechanic so I'll find out soon enough. Hopefully that's it. The problem just sprang up out of nowhere. And as I mentioned, it runs just fine when the gears are engaged (manual tranny).
Pardon my ignorance, but what is "TB"?
