Originally posted by raytour95:
In further detail, mine is actually stuck at high and I have no air blowing at all! The stupid knob won't turn at all, it feels like the switch welded itself to itself. I can't even pull the knob (don't know if was meant to come off actually). Is this the same problem as with you guys?
Not the same as mine. My fan would only blow on high in the afternoon, but worked fine in the morning. It was the heater blower resistor recall that did the trick for me. Sounds like you have another issue all together.
Someone else will come to your rescue. :p
