#67657 08/02/02 01:16 PM
I know this has been posted before. I couldn't find it; so here it goes. When the ac is on high, it works fine, but at any other setting, it dosen't blow anything. Any suggestions?
1999 Contour SE
Sony Xplod 50x4 cd player
APC resonated exhaust tip (just for the cheese factor)
Coming soon:
35% tint done by Madavi's Motor Sports
All new speakers
the loudest muffler I can find
#67658 08/02/02 01:26 PM
#67659 08/02/02 03:39 PM
W
wip Offline
W
sounds like it could be the resistor pack, The suject of a recall on some, IIRC. You have the classic symtoms, fan only runs at high speed. The resistor pack is located in the car's air duct. Not sure if under the hood. but I know there is one. It looks about 1 1/2 X 2.5 inches, has a plug on it with maybe 5 wires. Just screwed into the air duct somewhere. If you are lucky, under the hood. The resistors look like little coils of wire, some heavy and some light. look for signs of overheating at the plug connection and the coils themselves. Another suspect is the fan high speed relay (don't know it you have one). These send power to the resistor pack for all speeds EXCEPT high. if it has failed (again if it has one) this could be your problem. Look in your owner's manual for the relay. It's in with the fuses. good luck... wink [/LIST]
