#805709 11/26/03 12:03 AM
Ok there's a little yellow like that looks like a battery standing on it's end, filled with water and there's a fan in the water. It used to come on when I first started the car. Now it comes on and stays on until about 1-5 minutes after driveing. Anyone got any idea what the light means and/or what could be going on?
- Mark
'98 SVT E0 Silver -TRENDWHORE! Selling out never felt so good!
#805710 11/26/03 12:05 AM
is that the low coolant light?
Traded in - 2000 SVT Black tan leather DMD, Pro-Flow 75mm MAF, SHO Shop Intake Mystery mod(awaiting installation) Now 2004 Acura RSX Type S 2003 Honda Civic Hybrid
#805711 11/26/03 12:18 AM
- Mark
Hahaha....awesome description.
That would be the coolant/radiator light; these cars are notorious for having an over-sensitive coolant light, thats probably your issue. Fill it up to a little above the max line with the proper mix of coolant. Should take care of it.
1998 Mystique LS: -2.5 Duratec ATX -Vibrant White -------------------- =Pics= =Info=
#805712 11/26/03 12:25 AM
its not a battery, but a radiator and its the low coolant level light... just add a cup of coolant to the overflow container and it will go out and stay out.. the coolant recovery tank has the sensor in it and it is very sensative and needs just a little more then the marks on the side of the container say where the full mark is located.....
no problem alot of other cars dont have this light and there is no problem with it comin on................... as long as you have coolant in the tank....
#805713 11/26/03 10:48 PM
i have a 2000 csvt, and my car does the same thing. once it warms up the light goes away. i've just become pretty used to it now. thanks for the help!
~*~Bonnie~*~ Amazon Green 00 SVT Contour, #? of 2150, born 2/00 (bought 7-16-03)
