looking for ideas what to look for. heres the problem. car will crank over, but will not start. new spark plug wires, check for spark thats good. fuel pump working but not getting fuel to combustion chamber. suspect injectors not firing.other wierd thing is when i turn key to on position the radiators fans come on.tryed my little sunpro code reader on it and it wigs out when i use it. now i know youre thinking pcm but i have a spare pcm and changed it out and still does same thing. called ford about wiring recall and they told me it was vin# specific and my car wasnt coverd,bastards. cause the wiring is crap, you touch and insulation falls off. please any ideas what would keep it from firing. thanx 95 contour se 2.5L atx
