Posts: 586 |
My passenger fog light is starting to become very annoying. Here is a history of when I had it changed.
2/1/01 - 40,521 12/12/01 - 50,515
I noticed it was out once again last night. I tapped on the light itself and it came back on. Is there some kind of short going on. Maybe the ground is not working properly????? It has been 8 months and 9,000 miles since it was replaced. What gives??????
The driver's side was replaced on 2/15/00 with 28,018 with no problems since.
Any ideas??????
Thanks in advance........
Posts: 2,277 |
seems we hear this a lot (people's fog lights burning out quite frequently - Elky and mklaro have had these problems). I'm doing a search right now in here to see how common it is (especially for 98's) so far I came upon this: (read what brapple wrote) http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic&f=3&t=007624&p= this one talks about inadequate seals, water getting in and burning the bulbs out: http://www.contour.org/cgi-ubb/ultimatebb.cgi?ubb=get_topic&f=3&t=006766&p=
Kim 2001 Mercury Cougar C2 1995 Contour GL Quote: Originally posted by shotwell: Yeah, I keep checking too. I'm afraid that just as the site goes down my car will burst into flames or something (knocking rapidly on wood)!
Posts: 804 |
Originally posted by Odysseus: My passenger fog light is starting to become very annoying. Here is a history of when I had it changed.
Any ideas??????
Thanks in advance........ Ed, are you touching the bulb when you install it? The oil in your fingers shortens the life of the buld significantly. Just a tought...
-Rob- '98 E0 Contour SVT #897, T-Red. FOR SALE: '98 E0 CSVT #2663 SilverFrost; stock & in very good condition. $7,800 KKM & BAT Intake Pipe, DIY cool air intake, Resonator deleted, TH fix; short shifter, rear spoiler, hood struts, fog mod, pre-98 sails, dings removed, A4 side-markers, clear head-light corners, T-red chrome front & back. Aussie Bar waiting for installation.
"Monkey is my business...and business is good!"
Posts: 586 |
I saw that thread earlier and I am starting to think that this may have something to do with it. If there is a crack in the housing, that would explain the shortness of life in the passenger bulb compared to the driver bulb. Any body else concur with this???????
Posts: 954 |
Unfortunatly I can't relate. I've yet to have a fog light burn out, and I'm at 36,000 right now. I did have to replace a tail light though.
88 Grand Marquis 00 SVT Contour (1584) 64 390 FE Big Block 02 Honda Spirit 750
Posts: 1,859 |
i bought my car a year and 3 months ago and i have replaced each bulb 4 times they only last a couple month for me if i am lucky
**HELP SAVE CEG!!! DONATE NOW!!!**
*This space for rent* Please call... 1-800-FOR-ELKY
All proceeds go towards saving CEG
Posts: 182 |
Yeah, I need to find the money to get new fog lamp housings. They BOTH have cracks on the bottom. Last time one went out was when I was driving in a HEAVY downpour. I figure, they're MADE for driving in the rain, so I SHOULD get them fixed so I can use them! I've changed them both twice in my year of ownership (bought the car March 23, 2001  ) and I HATE changing the passenger side, and that's the side that went out in that downpour. I had an appt. for an oil change that Saturday (happened on Thursday) so I figured Id have the dealer change the bulb while the car was on the lift, so I bought my own bulb and had the dealer put it in. When I got my bill...I was charged...check this out...$36 TO CHANGE THE BULB ALONE  !!!!!!!!! I was charged $60 total, with oil change, greasing the suspension bushings, and changing the fog lamp...grrr  but I need to get new housings, I hear they're about $90 each...right?
YOUNGEST CEG MEMBER  1995 Mystique LS V6 ATX, Moonlight Blue Clearcoat Metallic, Atlantis blue cloth. Fully loaded except leather, sunroof, and CD. 1990 Pontiac 6000 S/E AWD Brilliant White with 2-tone Gray leather, fully loaded
Posts: 594 |
the passanger side is more likely to go out in wet weather becasue it takes more abuse from water on the side of the road. When I had problems with mine I could see the water in the light.
My fix was I took out the casing and sanded the cracked area down. I then used silicone and some aluminum flashing to seal the area. That was about a half to a year ago and in a heavy down pour the other week I had no problems and I was hitting some puddles on the road
Son - 1995 Mystique LS Zetec 5-spd --> newest "mod" -> a girlfriend by my side Father - 1995 Contour SE Duratec 5-spd Mother - 1999 Contour SE Sport Duratec 5-spd My CEG Registry My Car My Home Page
Posts: 586 |
I will be checking the fog light housings to see if there are any cracks or potential for leaks. That seems to be the consensus. Thanks......
Posts: 231 |
I have not noticed any cracks in my housing but even so I replace each fog light about every 4-5 months (alternating sides). Fortunately it is not as bad as you Elky, but it is enough to be annoying.
| Aaron | 1999 SVT E1 | silver | 147 of 2760 | If you want to throw away your license in about a week, this is the car for the job | car and driver
