My friend's 1995 Mystique with the 2.5 and auto tranny is stalling (badly) when accelerating normally. Same thing when going up any kind of hill at all.
Runs fine at idle, and runs fine on level ground at constant speed.
I have replaced the fuel filter, no help.
It has a brand new set of plugs in it.
I also put a new Mass Airflow Sensor on this thing (on advice from AutoZone) but that didn't seem to help it at all. I did not , however, unplug the battery (to reset computer ?) when i put the new part on .. should I have ?
I have never had a check engine light.
I've also checked the fuel pressure, seems to be at about 40 lbs which I belive is about right.
I'm running out of ideas fast.
The temperature is running in the normal range, on the cool side, even on the hottest days.
Thanks for any ideas,
DLD
ps i'm not familliar with some of the acronyms i'm seeing here (iac?) so spell 'em out if you don't mind
