#67519 07/31/02 09:19 PM
SVTMike Offline OP
I dont know if its a problem or not. But lately every time I turn the AC on it makes this high pitch whining noise. The noise gets louder when I accelerate. Anyone know what this is? Is it a problem?
~~~~~~Mike~~~~~~
Silver 2000 Contour SVT
# 1200 of 2150
#67520 08/01/02 03:48 AM
SVTMike Offline OP
Anyone?
~~~~~~Mike~~~~~~
# 1200 of 2150
#67521 08/01/02 07:11 AM
You might have the "moose". Do a search on it in the problems forum.
1995 Mercury Mystique GS Sport
2.5 Duratec
K&N Drop In
High-Flo exhaust
Tint
Bad things:
- clear coat flaking off!
- timing chain going
- idler pulley defunct
- rack and pinion going bleh
- Ford dealerships
#67522 08/01/02 08:12 AM
9
9
Uh, doesn't sound like the moose. The moose makes an appearance at startup idle. The moose doesn't have anything to do with the A/C. Trust me, he showed up in the middle of the winter for me.
But your A/C? I would get it checked out as soon as possible. If it is whining there is probably something wrong with it, but I don't know what.
1999 CONTOUR SE SPORT
2001 HONDA CIVIC LX SEDAN
- 1.7L 5 Spd
- '02 SI RIMS
- Reverse Indiglo Gauges
"Biblical principles work, there are no exceptions."
www.geocities.com/jesusfr7282000
http://www.7thgencivic.com/members_rides/member.cfm?id=5895
#67523 08/01/02 08:55 AM
I get this on occasion too. Under load (acceleration, slight uphill etc), I hear a high pitched whine. It isn't too loud though. I honestly don't pay too much attention to it. I've had it on & off for the last ~15 k or so.
52xxxK now.
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course."
#9 - Hitting .400 for ever
"Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez
"The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
#67524 08/01/02 09:37 AM
H
H
Rad fans are a possibility, although I don't see how acceleration would affect noise. Speed might, due to air flow on blades from car movement. Cause could be either bearing or air flow whistle.
Pulling fan hi-speed relay (r2 - black, engine fuse box) for a short test would confirm/eliminate this source. Perform test from cold start, a/c off, relay out. Start, run, a/c on, listen, a/c off, end test, ignition off, restore relay.
If your car is still under warranty you might want to get it checked at dealer in case it's compressor related.
stock CD on LS, cass on LX
4 wheel discs on LX only
#67525 08/01/02 12:45 PM
SVTMike Offline OP
Thanks guys. Looks like its time for a trip to the dealer. mad
~~~~~~Mike~~~~~~
# 1200 of 2150
#67526 08/01/02 07:14 PM
I've had something that sounds a lot like this for ages and ages...not quite the moose, but similar. Usually happens when I start the car and turn the a/c on right away, and also sometimes when I start the car when it's still hot.
I've always assumed it was the auxilliary fan kicking in. Maybe I should get mine checked!
Craig
99SVT black/tan
2725 of 2760
