#67509 07/31/02 07:30 PM
When I drive 45-70 m/hr the front end of my car shutters. It gets progressively worse above 45, but stops above 70. It only recently started doing this. Is this caused by faulty front sway bar links or front tires out of balance? Anybody that this has happened to I would appreciate any help.
1998 Silver Frost SVT
Purchased 01/10/02
Mods so far:
-Fidanza aluminum flywheel
-Clutch upgrade
-Clarion ProAudio system, DSP, 13 Band EQ
Future mods:
-Intake upgrade
-Performance plug wires
-Autolite double platinums
-Konig 18 X 7.5 Toxxin's
-Koni's and Eibach coil overs
-Rockford amps, 3 12" Rockford subs, etc..
(Just needs to be installed)
#67510 07/31/02 07:49 PM
N
N
I've been told if you can "drive through it" it's a tire issue.
You may have lost a wheel weight.
Have the front's balanced and see what that does.
#67511 07/31/02 07:52 PM
Someone once said that they knew of a place that balanced tires while they were on the car!
Anyone ever heard of this? If so, does anyone know how this is done?
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
#67512 07/31/02 07:54 PM
That is kind of what I figured. I just wanted to know if anyone else had this happen.
Purchased 01/10/02
Mods so far:
-Clutch upgrade
Future mods:
-Intake upgrade
#67513 08/01/02 05:58 AM
Sway bar links help keep the car level when making turns. A speed sensitive shudder felt in the steering wheel is more likely tire balancing.
Scott
