#802383 11/21/03 10:18 PM
I have posted this with another problem I had in the troubleshooting but my tranaxle problem isn't going anywhere over there so I figured I would post here.
My problem
The transaxle hasn't been downshifting when you manually downshift from drive to 2nd or to 1st without giving it a couple taps on the accelerator pedal, fluid is full, clean, not burnt and is not brown at all.
Alan 93 Acura Integra LS 5spd Horizon Gray Metallic ------------------------- -96 Gl Zetec ATX- Totaled as of 11/29/03 at 4pm Champagne Metallic CC Pics
Try replacing the Range Selector Sensor that sits on top of the tranny.
This tells the Computer what gear you are selecting when you move the shifter.
Also keep in mind that at higher speeds, the Computer will PREVENT
the tranny from downshifting until it reaches a safe speed.
Pete... 2004 Mercury Marauder 300A Black Clearcoat/Dark Charcoal LEATHER DOB 10/31/2003 DOP 1/2/2004 www.mercurymarauder.net
