Originally posted by jborge: To remove the cap you will need some sticky stuff! I used weather stripping to pull the plastic cap off. Some people have uses duck tape, that did not work for me.
Any material with a STICKY SIDE will do. May take several tries. I have also heard someone use a razor blade to get in between the two plastic pieces. Just be careful!
1996 Contour SE Sedan 4D (Royal Blue) Duratec V6 2.5L 24-valve DOHC Automatic 75,000 miles No Mods (unless you call the DMD a mod) Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
