Not sure what you mean by 'now and then' but a 44 code indicates air bag monitor has detected a ground circuit problem with RH crash sensor. Visual check of mounting would be the place to start. Sensor is readily visible after raising hood; mounted on the upper rad support, just to the pass side of car centerline - a little box attached to an inverted 'L' bracket.
