Hey everyone..this could belong in the Troubleshooting or even General Mods, but seeing as I'm F/I'ed, maybe I can slide.
I just installed my Walbro 255lph high pressure intank pump. Upon startup and relearn the car has developed a hickup at idle every 15-20 seconds, and has a serious hickup on throttle tip in. I checked for codes and had a pending code of P0190 "Fuel rail pressure sensor malfunction". Now I went with the high pressure unit because of it's higher availability to that of the low pressure....plus the "powers that be" stated that the rail pressure sensor would /could regulate the appropriate amount of fuel.
I spoke with Keyser and he stated that upon relearn given so much extra fuel over a stock fuel pump relearn that the fuel maps could be way out of wack and need to tune themselves in....Enough to hickup though?
Any insight/advice/opinion is greatly appreciated guys.
TIA
