Hi,
Per my Name, I have purchased a Contour that needs new carpet among other things. While in the process of removing the center console I broke the shifter. It's hard to describe, but for those of you who have removed the shifter before you'll know what I'm talking about. The screw in the side was removed, but the shifter did not budge. Unfortunately I began to twist and that broke the black plastic bottom portion of the shifter and tore the overdrive wires off the button in the shifter. I'm going to try to glue the plastic peice back on and solder the wires back together, but if anyone has any advice let me know. Also if anyone has replaced their carpet before and has any helpful advice, please post. Thanks much.
