Posts: 46 |
I want to make my cig lighter connector turn off w/ ignition for my escort radar detector... anyone have good idea on best way to do it.
'00 SVT
49,000 Silver Frost
b&m short shift, 17"tires, driver
100mph+daily
Posts: 717 |
Does "escort radar detector" mean it's in an escort? As far as a contour goes. They automaticially shut off with ignition. Mine does at least.
90' Bright Orange Mustang
65k - 13.306@105.1
Looking for another CSVT
~Blas~
Posts: 3,627 |
why dont you just hard wire it in to an acc. power supply. the radar detector that is. it would be much easier to do that then to pull the consol and rewire it like that
Trollin the boards as of 9/23
Originally posted by GS474: stock hp is never enough
Posts: 46 |
car is a '00 csvt and my cig. lighter does not turn off with the ignition. I have run a clean extension from the RD under the dash to the cig lighter and now want it to go off with ignition. I want to keep using the cig lighter plug so I can move to other cars still if need be. thanks
'00 SVT
49,000 Silver Frost
100mph+daily
Posts: 3,627 |
lot less work to just unplug it when you get out of the car
Posts: 332 |
you could always add a switch to the cig lighter if that makes ya feel better or unplug it like the rest of us non-lazy people
Posts: 46 |
you guys aren't gettin it... the whole point is to not have to unplug or use a switch....
'00 SVT
49,000 Silver Frost
100mph+daily
Posts: 1,580 |
If you're worried about it shutting off for sake of saving yourself from a dead battery, dont worry. The amp draw is so minimal that you'll never see the effects of it. I've had mine on since i got it over a year ago.
** Mike **
"You might beat me in a straight line, but I'll embarass you in the turns"
Posts: 625 |
mine stays on when the cars off, so i wired mine in with the sunroof control panel. Now it turns on and off when the ignition is on.
98 SVT
#1652 of 6535
My SVT
"If everything seems to be going well, you obviously don't know what the hell is going on."
Posts: 332 |
Originally posted by slocraiger: you guys aren't gettin it...
oh we get it...
were just suggesting that you unplug it and if you do forget to unplug it then it would be no big deal
