On my '95 Duratec I removed the lower shield, under the front bumper. If you jack the front up some, you should be able to find the plug with a flashlight. There is stuff around it, so you have to eyeball it from a particular angle. It's on the lower passenger side of the radiator. Mine had a plastic plug with a cross hole. I was able to feed a slotted screwdriver in and unscrew it. Mine had a catch so it would not fall out. Get a big drain pan, as it sprays a bit.
