Doba Offline OP
I am trying to make it so nobody knows what kind of car I have. I have done the mesh grill, removed badges, and replaced the side sails. How can I get rid of the rear Ford emblem on the trunk? Is there a chrome insert?
Every hour wounds. The last one kills. Black 99 SVT
Doba Offline OP
Anyone at all?
Doba Offline OP
Double post. Sorry.
R_G Offline
I saw some ppl changed it, but can't recall who... I saw them pix with changed rear Ford emblem, I believe it was an "SVT" emblem or something...
U have a better luck to ax this question on weekdays, more ppl are browsing the Forums then....
I took off the chrome strip (im assuming you have post-98) and carefully put vinyl tape over it and cut around the cirle with a razor. i dont know about removing them. PS ive done exaclty what your doing,by removing all the emblems, people always think its an escort or taurus. it insults me when they say ahh nice escort
When I had the stock Tour center reflector/tailights I just went to Pepboys and bought this blackout tape (used to cover up unwanted chrome trim) This worked real well and I even went as far to buy the small SVT emblem from the 1994-95 Cobra/Lightnings to put in there. It fits w/o any problems, but you do have to bend it down a little bit when installing it because of the curvature, no biggie I assume you could use electrical tape as well and even though your going to have to overlap the tape because its not going to be wide enough, who cares, because if you put the SVT emblem in there you'll hardly notice it Also, before I forget, I did the same thing to Ford emblem in the front as well, it looks like it came that way, a "must do" mod for the SVT enthusist looking for something different, but not cheap lookin'
Q
Q
I have one of these nyoceboi emblems I just got done painting it black now it blends in with my rear chrome strip that is also painted black, and I also have no emblems,badges,moldings etc... I get it all the time..."what kind of car is that?" I love it If you can find one of these I recomend you snatch it up!
-Jeff-
1998 Black SVT Morette Twin headlight conversion Street flight turbo kit collecting dust! Rebuilding my 3.0L check it out
Q
Q
oh I forgot if you do get one and you wanna paint it you have put some muratic acid all over it then clean it so the paint sticks to it!
-Jeff-
FYI if you remove it , you're going to have some holes to fill.
90' Bright Orange Mustang 65k - 13.306@105.1 Looking for another CSVT ~Blas~
-Jeff-
Well that's not the only way the paint will stick. From what i read it's something you'll probably want to do on the front. Makes chipping and all that less likely I guess. But all I did was scuff it up real good and so far it's stuck and looked fine.
