#67170 07/27/02 08:03 AM
cano Offline OP
It seems that my e-brake it will only engage in the left side. With the level all the way up my right tire will rotate freely. Any advice what could cause this. I did try the search option and only came up with one thread. Thanks
"the rats are on the cheetos again"
Jet mechanic
98 silver frost SVT
DMD
K&N FILTER 36,300 MILES
PIONEER 6CD CHANGER AND SPEAKERS 2 BAZOOKAS
#67171 07/27/02 08:42 AM
9
9
Have you checked your ebrake lines for stretching or a break in the line? I don't know, I may be completely off, but that would be my first guess...
1999 CONTOUR SE SPORT
2001 HONDA CIVIC LX SEDAN
- 1.7L 5 Spd
- '02 SI RIMS
- Reverse Indiglo Gauges
"Biblical principles work, there are no exceptions."
www.geocities.com/jesusfr7282000
http://www.7thgencivic.com/members_rides/member.cfm?id=5895
#67172 07/29/02 04:15 PM
cano Offline OP
I did check and is pulling on the level on the caliper, I also try to pull on the level myself to check if it was not pulling enough and it did not brake or stop spining. Any other sugestions
Jet mechanic
98 silver frost SVT
DMD
#67173 07/29/02 04:46 PM
H
H
Are you able to pull handbrake lever up so that you hear 7 clicks?
stock CD on LS, cass on LX
4 wheel discs on LX only
