Posts: 154 |
I have one of the first Contiques (built 9/1994) and the early ones (95 and maybe 96?) didn't have a "low fuel" warning light - I think enough managers in Dearborn running out of gas in theri company cars brought about that change  When I had the original gas tank, the fuel guage was very linear and reliable. After I had the gas tank replaced (recall, I only got one but some people had theirs replaced 2x...) my gas guage started behavin gas you described. The most annoying feature is when I'm cruising at constant speed on level ground, and only have a couple gallons left, it swings back and forth above and below the E line, below the red zone. (I have a red zone on my guage, I think that's another thing that disappeared at one point - saved $0.0037 a vehicle!) It's been annoying, but I've gotten into the habit of filling up whenever it gets below 1/4 on the dial. If I let it get to dancing around the "E" I still usually have 2+ gallons left. -Peter
04 Mazda 6s V6 MTX, in service 10/28/03
02 Subaru Impreza Outback Sport 165HP 4cyl auto AWD
former: 95 Mystique LS V6 MTX [11/14/94-5/19/04]
Posts: 228 |
Originally posted by Oo.et.oO: long before your pump overheats your car will stall and the pump will turn off. BTW, i don't think the poster meant run it until it stalls on each tank. just run it until it gets very low. also note that the nominal amount of trash in your filter should stay the same.
This is the post I was referring to. I KNOW it is before your car stalls. That wouldn't be a great habit of filling up your car. Do it before it gets lower than 1/4.
Originally posted by Zoomin 3L: YA BUT DON'T RIDE ON THAT LIGHT. Matter of fact I don't even ride less than a 1/4 tank. It ruins your fuel pump in time! (fuel pump gets hot, gas cools fuel pump, no gas, HOT A$$ PUMP )
Running it very low it is not a good idea. I'm still convinced that will draw more dirt from your tank plus the risk you can run out of gas if somehow get stuck on jammed traffic.
But I don't hold to a beleif forever. If I get enough evidence that running low is BETTER than fueling before 1/4 I'll give it a try.
Pablo Quintana
98 SE Sport Contour
Honduras, Central America
Posts: 1,231 |
I've always let it trip the light, then drive for about 20 more miles. Otherwise, I'd end up filling the tank more than twice per week.
edit: to be honest, my car runs a LOT better when I have less that 1/4 tank. Just seems more powerful. Sounds like the reverse of what other people observe.
-06 GTO Torrid Red/M6
-98 LS with BPU
-05 Honda Odyssey EX-L
mv .zig ..\for\great\.justice
Posts: 4,220 |
I guess '97s don't have these low fuel lights. I've never seen one, and I'm looking at a spare cluster right now and there's not one anywhere on here.
I've got my tank low enough that I put 14.5 gallons in it, so I'm sure if there was a light, I'd have seen it on that occassion at least.
2003 Mazda6s 3.0L MTX
Webpage
2004 Mazda3s 2.3L ATX
Posts: 23 |
Believe it or not, most automotive fuel indicators act in a non-linear fashion by design. I would expect the Contour is not exeption. I worked at Visteon for a spell where we manufactured fuel delivery modules for Rangers and F-150s. My experience is that there is an algorithm that determines needle position based on input from the float mechanism. This algorithm takes into account several things: 1) it dampens fluctuations due to sloshing of fuel and 2) Customer's expectations--meaning a driver wants to see the tank as "full" for a while after filling up. Also, a half a tank gives the driver a feeling of security, so it tends to dwell there. Once the tanks starts to run down, it moves to "E" rather quickly, presumbaly to give the driver ample warning that fuel is getting low.
In other words, the behavior that is being described most likely is intentional...
'99 SVT Contour, K&N, B&M, DMD, 'Foamed' Chassis
Posts: 328 |
Originally posted by pabloquintana: Somebody else said on these forums that without gas your fuel pump overheats because it is cooled by gas.
NO GAS = HOT PUMP = ON IT'S WAY TO HEAVEN
I'd rather change my fuel filter more often.
I won't try your suggestion.
I may have posted that awhile back...most of the auto folks agree that keeping your tank at 1/4 or above keeps the fuel pump cooler so it will last longer. Also since I average around 26 mpg, the fuel gauge usually reads 3/4 after 100 miles, 1/2 after 200 miles and 300 miles at 1/4. So if my miles are more at each interval I know I'm doing better than 26 mpg.
Now that the winter season approacheth, I'll probably start filling up at the 1/2 mark or 200 miles whichever comes first. This is supposed to keep condensation from forming and causing the gas line freezing up. This probably is not a problem in Central America!
- Jim
Our yardbirds:
Belvedere, our '96 Jeep Cherokee, 4.0L ATX, 85,000 and going strong
Spencer, our '03 Chrysler PT Crusier, 2.4L ATX, 28,000 and just getting started
Posts: 566 |
Mine is the same way! Just seems alot more responsive than it does when its full. Whats up wit that?
99 Blk SE Sport
2.5 CD4E
Euro Focus SVT Wheels
5 % tint
Mesh Grilles w/indiglo ford
KKM intake filter
FMS 9mm wires
Superchip
Signal mirrors
Fog lamp mod
Dingless
A6 sidemarkers
Duals
SVT springs/struts
Posts: 225 |
The reason it feels more responsive is easy:
Gas is heavy... 14 gallons of fuel is a considerable wait gain for your car... the less fuel you have, the lighter your car is, the faster it will go. I like to autocross on less than 1/4 tank, cause it's as light as I can possibly get my car.
And part of the reason that the guage doesn't move for awhile after fillup is partly what path914 said, the float (which i honestly believe must be remarkably similar to the float in your toilet tank) can only go to the top of the tank.
But what does every single one of you do when you fill up? You top off. The pump handle doesn't shut off untill the gas is partway up the filler neck, which means the tank is more than full. Then you keep squirting more and more gas in there to get as much as possible to lengthen your time between fillups. That means you've probably got close to a gallon of fuel just in the filler neck that you have to burn up before the level in the tank starts to drop.
Agree/Disagree?
Peace
Jed
MrRoarke865
'98 Silver Frost E0
'02 Honda Shadow ACE 750
MrsRoarke865
'97 Mystique
2.5 ATX
Posts: 228 |
Originally posted by draonbreth32: That means you've probably got close to a gallon of fuel just in the filler neck that you have to burn up before the level in the tank starts to drop.
Agree/Disagree?
Agree. I even shake the car when filling to let more gas in. I beleive that works to get almost a gallon extra.
Pablo Quintana
98 SE Sport Contour
