Posts: 26 |
I apologize if this has been answered before, I looked through the archives but still not clear on this. Do I need the friction modifier with Ford's new synthetic tranny fluid? (XT-M5-QS) '99 SVT Thanks.
'99 SVT (black)
Posts: 465 |
Off the top of my head, I think with the "honey" you don't need the FM. You only need the FM with synthetic Mobil 1, I think.
Old car: '98 SVT T-Red
K&N air filter; Ford Focus RS shift knob. Off to be auctioned off somewhere.
New car: 2003 Honda Accord DX Sedan, 5-speed.
Posts: 644 |
I started off with the straight Ford "honey", but shifting was worse than with the Mobil1 / FM cocktail.
I since added 2 oz. of FM to the Ford fluid, and shifting is much better than it ever was with the cocktail.
Hope this helps.
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 976 |
You need the FM with Mobil 1 or honey.
Posts: 751 |
Originally posted by kinger: You need the FM with Mobil 1 or honey or Red Line.
fixed
Whirling dervish of FFOG.
Posts: 4,693 |
I also have the Ford "honey" with friction modifier. It works very well.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 21,197 |
Originally posted by weargle: Originally posted by kinger: You need the FM with Mobil 1 or honey or Red Line.
fixed
THE REDLINE MTL HAS FRICTION MODIFIER IN IT. Kinger posted that for a reason.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 4,693 |
Originally posted by todras: Originally posted by weargle: Originally posted by kinger: You need the FM with Mobil 1 or honey or Red Line.
fixed
I suspect that the Red Line doesn't have enough friction modifier, if it did, it would shift as good as the Mobil 1 cocktail, ATF+3, or Ford "honey" with friction modifier.
You should realize that there is some level of friction modifier in many trans fluids. Mercon has friction modifier in it, but not enough.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 9,602 |
Originally posted by Big Jim: I suspect that the Red Line doesn't have enough friction modifier, if it did, it would shift as good as the Mobil 1 cocktail, ATF+3, or Ford "honey" with friction modifier.
I feel the Redline MTL shifts much better then the Mobil 1 with FM cocktail. It was a noticeable difference.
I also don't see why it would be a significantly worse cold shifting fluid. It has the same viscosity as ATF when it's cold.
I have been very happy with the results to date and there is no arguing that is protects much better.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,254 |
thats what i used with half bottle FM from ford, shifts very smooth
