Ok, where do I start...
I'll start positive, I love my SVT.
There, now I won't feel so bad when I get pissed off while I'm typing this post.
A few days ago I went to make a left turn, flipped my blinker on and I got the "crack-mode" speed blinker, turns out, my rear signal was out. I figure, ok, bulbs blown, I'll replace it this afternoon. Only, that afternoon, the blinker works.
Then the next day, my sunroof can't seem to get the juice to open upward. Slides back fine, so the motor seems to be fine.
Same day...car idles rough, stalling 3 times while at a stop various times throughout the day.
Today...I'm sick of it, pop the hood to see if the stereo is causing a problem, nope.
The (+) battery terminal is completely covered with blue-green corrosion, which I can understand. What got me, was the brace that goes over the battery. The bolt on the front side of it holding it down, was also corroded, as was part of the actual brace itself. Pulled back the vinyl battery sleeve/holder, and there is fluid in there. Oh great a leak.
I quickly drive to the part store where I got the battery about 3 months ago, he looks at it, grabs his tester, and tests the charge/hold of the battery. Absolutely perfect, took it to my father/mechanic, put his tester on it, same results.
My question is...
What the hell is going on?
Onboard computer?
Alternator?
Gremlins!?
Please help
