Posts: 12 |
i have an automatic and i hate it, need to convert to stick, anybody have an assembly for sale or does anyone know what kind of trannies fit the 2.5???????
Posts: 1,196 |
sell the ride and buy one with a stick.
2004 Evolution VIII cams-exhaust-tune
315whp 12.7@109
Posts: 332 |
Two words for ya: time & money Your going to need a lot of both if ya want to pull this one off
Posts: 8,301 |
Originally posted by BStoneMega: sell the ride and buy one with a stick.
Ditto, too much work otherwise, although it has been done on a Focus, I believe.
-Ken V.
psycho_bass@hotmail.com
Posts: 4,714 |
Its also been done on a Cougar. The only tranny that will work is the MTX-75. The total cost weighs in at about $3000 and requires the following list of parts, as well as reprogramming your ECU:
MTX75 Transmission $1600?new $~700used Clutch Disc $100.21 Plate $103.20 F7RZ-7550-AA & F7RZ-7563-AA Clutch Slave cylinder $73.84 Flywheel $94.48 Left half shaft $150? Right jack shaft $50? Clutch Master Cylinder $29.19 Clutch Pedal Assembly $178.62 F7RZ-2455-AA Clutch Hydraulic line upper $15 Clutch Hydraulic line lower $15 Clutch fluid supply line $5 Mount-fender side $85.22 Mount-tranny side-left $41.25 Mount-tranny side-right $40 Mount-cross member side-right $36.97 Shift Tower Assembly $72.97 XS8Z-7210-BB Shift boot $29 regular $99 leather Bolts- Clutch to flywheel $2 Friction Modifier $3.60 XL-3 Crossmember $450 Shift cables $45 3 quarts Mobil 1 synthetic ATF $15 Vehicle Speed Sensor-mtx $50 134Kohm resistor $1 Radio Shack
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 1,746 |
Probably be beter off just getting a donor car.
