#67064 07/25/02 02:23 PM
'99 Contour SE seems like the rpm are excessively high. At 75mph it runs right at 3400-3500rpm. Is this normal? Never had a car that revved so high while cruising.
#67065 07/25/02 03:42 PM
MTXs are that high.
My ATX revs at ~ 3000 RPM @ 80 MPH.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
#67066 07/25/02 03:46 PM
O
O
Mine revs at 3250 at 75MPM.
#67067 07/25/02 04:01 PM
I would be grateful for a higher revving engine. Higher revving burns off more gunk in the engine and leaves a cleaner running engine.
Plus, 3000-4000 RPM is not that high, especially since the car redlines around 6000-7000 RPM.
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
#67068 07/25/02 04:06 PM
My ATX runs at 2500rpm@70mph.
99 SE Sport..ATX
SVT exhaust
SVT zip tube and air cleaner assembly
Tinted windows
17" Cougar Zn Wheels
#67069 07/25/02 08:37 PM
H
H
quick question... since my 98.5 duratec isnt dampened beyond 4,000 rpm, I should be able to sustain any rpms below 4k on the highway without causing abnormal wear... is this true?
98.5 SE Sport
2.5, MTX
-Bosch Platinum2's, Ford Racing 9mm
-Drop in K&N with improved cold air bandwidth
-No Resonator
-foglight wiring mod, 885's
-recontented clock
