Posts: 417 |
I have an exhaust shop chop my SE's exhaust off about 3 feet from the back, and they replaced it with a "Y" pipe. This was to fit the new SVT rear bumper I got. The exhaust has no mufflers, and the size of the pipes are 1 7/8 inches. (oh yeah it sounds pretty good too  ) Now, the problem I'm having is after about 6300 rpm my power dropps WAAAY off, and it even backfired on me at 6700! Is this a case of not enough backpressure, or too much backpressure?? Also how bad is it to run the car this way??
99 Ford Contour SE Sport Manual V6 SVT front/ rear bumper /w Aussie grille Jet black Premier DEH-P740MP head unit matrix display, plays Mp3s!! 800 watt Kenwood amp 2 12" Polk Audio subs Blue "euro" headlights Eibach Pro-Kit springs 17" Enkei RS-5 White Indiglow gages
Posts: 417 |
Posts: 1,559 |
Sounds like the piping is too small for the exaust flow. You might want to go up to 2"
Posts: 1,537 |
The pipe sizes on an SE are 2.25" all the way through. The SVT is 2.5 at the Converter, and drops to 2.25 on each pipe after the split.
You need a muffler, either in place of the resonator, or on each of the pipes after the split. Most people put a high flow glass-pak in place of the resonator, and replace the rear mufflers with pipe.
I dropped my exhaust and replaced it with a used SVT exhaust, minus the resonator.
SOUNDS GOOD...mmmmmmmmm
Pete... 98.5 SE Sport Duratec ATX (P66L) Black Clearcoat on Greystone DOB 11/21/1997 DOP 12/25/1997 PIAA 510 Super White Driving Lights SVT CAT-BACK EXHAUST (No Resonator) DiabloSport Chip (LPQ4) - Engineered To Raise Hell Too many other mods to list... Sounds sweet, runs quick... Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
Posts: 291 |
YEAH, YOU CAN ONLY GO TO A BIGGER PIPE, NOT TO A SMALLER PIPE FROM A BIGGER PIPE.. TOO MUCH BACK PRESSURE.
Posts: 417 |
So it has too much backpressure?? Even though I went form a single exhaust setup with a muffler (witch mufflers produce backpressure) to a duel setup, which has more piping and probably all together would equal about a 2.5" exit (combinding the 2 pipes into their square areas). Sorry if I talk stupid, but I'm not firmiliar with exhaust too much. Anyway, how bad is it to run my car this way if it has too much/ too little backpressure
Posts: 1,701 |
It's bad... If your backfiring, your risking some potential cylinder and or cat damage. The Y pipe to smaller pipe :rolleyes: doesn't make any sense and will make a mess up your exhaust flow.
Posts: 1,355 |
SE Stock exhaust is 2" piping. SVT stock is 2.25".
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 147 |
At the engine rpm you listed.... you could be hitting the rev limiter / fuel cut off limiter. The ECU is designed to keep you from over revving the engine. I think it backs off the timing and starts to shut off the injectors, thus preventing you from over revving the engine.
99 SE Sport..ATX SVT exhaust SVT zip tube and air cleaner assembly Tinted windows 17" Cougar Zn Wheels
Posts: 5,805 |
FWIW...now such thing as too little back pressure...only an non-updated calibration/intake system to match it!
