#791279 11/07/03 11:22 PM
No laughing...
What causes a wheel bearing to need replacing? I've searched the site with answers to cost and how, but nothing on why.
Thanks.
99 Sport SE - Zetec Mods: My wife vacuumed it last spring , my son wiped up his hot chocolate spill in December. My daughter found the tooth she lost last week .
#791280 11/07/03 11:49 PM
Are you asking why it wears out, or what happens when it wears out? If you're asking why it wears out, all moving parts will eventually wear out due to friction. The only thing keeping the moving parts from wearing is a thin coating of grease, which is bound to wear out eventually. As far as what happens when it wears out, the metal on metal contact eventually causes enough wear that there is a lot of play between the bearings and the race. This lets the wheel shimmy and shake, and I suppose ultimately fall off.
#791281 11/08/03 12:23 AM
in the case of my fathers car is was the conditions of the roads he drove to work every day. they were bad roads that were not the best and were often wet. I beleive water got into the bearings and they started to rust, causing the noise. this would go with the fact that the passanger side went before the drivers side
#791282 11/08/03 01:03 AM
Would this include shaking at speeds over 50 and excessive shaking on moderate braking? I am exeperiencing this and since wheels bearings have been the subject of alot of posts i thought i would ask.
Formaly FLCEGkid Chris Bertrand 1995 Ford Contour Gl 2.5 V6 MTX FOR SALE! Somebody please buy my Fiberglas hood!!
#791283 11/08/03 03:27 AM
FLCEGKid,
When mine went out, it was a mild, uniform vibration. It felt like I was driving on a roughly paved road. Maybe I just repaired it before it got very bad, but the symptoms were not severe, and they existed at all speeds. It was noticeable when I went straight ahead, or when I turned one direction, but the noise and vibration stopped when I turned the opposite direction. When I jacked up the car, and shook the wheels, there was quite a bit of play in the wheel with the bad bearing.
I'm having symptoms now very similar to what you describe, but I don't think it's the wheel bearings. I'm getting a slight to moderate vibration most of the time, particularly at speeds above 50, but very noticeable when I brake. I wish I knew what it was. From my experience, and from what I've read in other posts, a tell-tale symptom of a bad wheel bearing will be that the symptoms stop when you steer to one side, but not to the other side. I'm not getting that now.
#791284 11/08/03 04:33 AM
Mine is going out right now and it sounds like a big concrete roller rolling on the pavement. Its a wierd noise. Mine has went through 4 in 3,000 miles though. The guy that was fixing it just now noticed that it was missing the outer snap ring. I think this explains the constant wearing out of the bearing in my situation.
Blaze
1996 Sport LX Desert Violet Pearl(purple) 2.5 liter V-6 Name:(Grape) Finally Fixed
#791285 11/08/03 04:48 AM
E
E
And after the second they never charged you right???
2000 CSVT Silver Frost: #942 of 2150 HID Projectors and Fog Light Mod, Optomized TB, MSDS headers 2003 Silverstone Z
#791286 11/08/03 06:01 AM
They charged me every time telling me that because the car was wrecked it was eating wheel bearings. The car was wrecked at 61,000. It would of showed up before now. I cannot get the snap ring anywhere. Hardware store---dealer---no where. Would the missing snap ring cause the bearing to eat up and go out?
#791287 11/08/03 07:11 AM
Mine is missing the ring on the passenger side inside. Plus my driver's side must be out, becuase it's consistently getting worse, slowly but surely. Whenever I drive dead straight, or do a left turn, I have a rubbing noise. It was diagnosed as the passenger side, so I got that replaced, and it did nothing. So I'm assuming it was the driver side this whole time....
I'm really not sure, because there's a TSB from Ford that notes "a rubbing noise similar to a bad wheel bearing" or something like that. From what I found, it didn't list a fix, just that they knew about it.
Goin' Round Traffic Circles @ 50Km/h!!! \m/ -- 1998 E0 SVT #2119 of 6535 \m/ -- 2003 Sentra SE-R Spec V
#791288 11/08/03 11:44 AM
Mine sounds horrible. It is now starting to make a pop noise. The last time it started popping it locked up, AAAAAAAAAHHHHHHHHH
