Posts: 9,602 |
I've run Dex-Cool in my SVT since about 2k (nearly 4 years later & 40k now) I love it and it's superior cooling and protection abilities.
Ran it in my 89 Conquest for over 60k and 3 Cavaliers for over 200k.
Never once had ANY cooling system related failures and it's great peace of mind to know you are not getting the particulate build up and erosion like you would the old phosphate and silicate coolant. (I.E. Green junk)
I also run a ~60% water mix to promote even better cooling.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 3,816 |
Why can't all ethylene glycol be green and everyone (manufacturers) be happy? So not too long from now, you will walk in and ask for ethylene glycol antifreeze and they'll ask "you want strawberry, bananna, blueberry, or lime?"
Posts: 1,049 |
do you guys prefer the pre mixed ainti freeze or the regular stuff.
Posts: 635 |
Since the absence of a drain on the block, an unknown amount of water remains after flushing, I put the calculated amount of straight antifreeze in and then top off with distilled water. I my case my water now actually comes from the dehumidifier. When I still worked at the phone company we use to have a "still" to make water for the those big central office batteries. Now days that's too costly, so they have a special filter to remove minerals. I use to always have 5 gallons on hand. No not moonshine--water! Paul
Paul
98 Mystique LS 2ea (07/97)(08/98)
Posts: 3,816 |
I get premixed to top off (I have a mystery coolant leak, fill overflow once a month) becuase it's easiar for that kind of stuff. It's cheaper to get the plain, then use tap water, but if you use distilled, I dunno.....
Posts: 7 |
Where do you guys buy your gold / yellow coolant...the Ford Premium Gold / Zerex G-05 stuff. None of the stores carry it around here...
2000 Mystique LS
Duratec 2.5L, ATX
Posts: 3,840 |
Holy old thread.
I'd assume you might check with the dealership if you can't find it anywhere else.
-SAV
Troll. 1997 VW Jetta MkIII GLS 5spd
All hail my appearance on CEG!
Posts: 7 |
True...I'd like to find a source for some of this stuff that has better hours and prices though. Also wondering, does anyone know how the extended life "mixes with all" coolant from Prestone (pale yellow I've been told) compares to the gold Zerex/Motorcraft formula? It's at a lot of stores and at a pretty fair price too.
2000 Mystique LS
Duratec 2.5L, ATX
Posts: 4,693 |
From what I have been able to gather from BOBISTHEOILGUY there is a difference. I'll try to briefly explain.
First off, I found G05 at Pep Boys. It doesn't seem to be stocked at AutoZone or Kragen anymore.
The green coolant that your car was built with (commonly called "conventional green") is ethelyne glycol (as are most coolants) as the main ingredient. Ethelyne glycol mixed with water has problems, especially in that it is corrosive to metals. To prevent that, additives are used to overcome the problems. The additive package in "conventional green" is mostly phosphates and silicates and it is heavy in each. Phosphates don't like hard water and is a bit abrasive on pump seals. Silicates fall out of suspension after time and leave a bit of gunk behind in the cooling system and are even rougher on pump seals. "Conventional green" truly needs to be changed fairly often to prevent fall out as well as once the additives are depleted allowing system corrosion.
The next big advance in coolant chemistry was OAT (organic acid technology) which replace both phosphate and silicate. The most commonly known of these is Dexcool. Dexcool is truly a superior coolant but it is not faultless. OAT in general doesn't seem to protect against cavatation in the same way as phosphate or silicate. OAT takes longer to build the protective layer than the other two. The OAT group that GM uses (made by Texaco) for their Dexcool is different from what Prestone uses, although it still meets GM's specs or it could not be call Dexcool. The GM (Texaco) Dexcool has a problem if allowed to run too low for very long and rust forms in the cooling system. This seems to be less of a problem with Prestone's Dexcool. As long as Dexcool is kept at the proper level and proper concentration, it is vastly superior to "conventional green" in that it doesn't have problems with hard water and doesn't have silicate gunky fall out and doesn't have abrassive material that damages pump seals. Dexcool is orange in color.
Ford and Chrysler have responded to the improvements with Zerox (Valvoline) G05. G05 is considered a hybrid coolant because it is OAT with low levels of both phosphate and silicate. It is also called HOAT (Hybrid OAT). The Chrysler stuff is (of all things to lead to confusion) orange. The Ford stuff is yellow. The G05 packaged by Zerox is sometimes nearly clear or slightly yellow.
Something similar to this has been used in europe for a while. It is a little hard to catagorize easily though. The maker of the coolant additive packages is mostly BASF, the German chemical company. BASF has a very long list of additive packages. Europeans like little or no phosphate because in general the water in europe is very hard. The stuff used by VW, AUDI, Mercedes, and Volvo is thought to be G05 or something very close to it.
The Japanese like coolant with no silicate and high in phosphate. They feel that a heavy dose of phosphate does the best for protecting against cavatation. Toyota Red is the best example of this. Even green Japanese coolant is high in phosphate and has little or no silicate. The newest formulations seem to be OAT but still with a dose of phosphate and they still avoid silicate.
Now we get to the newest Prestone product that claims to be for "any make, any year". It seems to be identical to Prestone Dexcool, without the orange dye. It is green or yellowish green. By not declairing that it is Dexcool, they don't have to pay royalties to GM.
Which one can be used with which cars? Even the experts don't agree. To err on the side of caution, the general feeling is that you should use whatever the car originally came with. That is getting harder and harder to do, especially since "conventional green" is getting scarce.
It is my personal opinion that you can use any of them as long as you change it at least as frequently as that coolant calls for. I have used Dexcool (Texaco) in the SVT since it was a year old. I change any colant once a year (it's cheap if you do it yourself). The Escape came with Ford G05 and I changed it and replaced it with Zerox G05 when it was a year old.
Sorry for the brain dump. Maybe this has been helpful.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 9,602 |
Great post Jim.  I run ZEREX Extreme and it's OAT based & 100% phosphate & silicate free. I started with Dex-Cool but that's hard to find anymore. At least here it is. (I have enough Zerex for another change each vehicle & I just did both this spring  ) I dislike the "All makes, all models" mixes with anything coolant (don't get me started!) because it's just a hodge podge of different formulas and is not remotely close 100% phosphate & silicate free. It's probably fine for folks using the old "green" coolant.
2000 SVT #674
