I have a problem with a door pin switch. On the driver's side front door, the swich has stopped working again. It stops working about once every year. Bascially, it just sticks down. If I push it in, it works a couple of times, and then stops. Also, the screw that holds it on rusts continually. I take the screw off and clean off the rust, and I've tried to make the switch not stick. However, it continues not to work. Normally I would just let it go, but winter is coming, and since my headlamps on chime won't work without the switch, i'd like to find a solution.
Any suggestions would be appriciated.
Thanks in advance.
