sylin Offline OP
After 7 hours hammering and tons of liquid wrench I finally got the front left rotor off, yahoo!
My 97 tour is still on original rotors and they have worn down almost to the ventilation ribs, not to mention the 22.2mm of minimum thickness.
During the process of hammering I cracked both friction surfaces and blew them off the rotor, leaving the "bowl" still rust seized on the hub. This gave my hammer a better way to fight by directly hitting the rim of the bowl. It turned out to be very effective.
By inspecting the removed "bowl" I found it was a belt shaped area on the inner wall of the bowl where it met the rim of the hub that actually rust-seized. Though there were some other minor rust areas, they had been all soaked with liquid wrench and well deformed. That belt came out dry.
Now I'm fighting against the front right rotor. I try to avoid too much hammering as I have to work lying on the floor and hammer with my left hand that has much less power and poor precision. Instead, I drilled a series of holes along the circumference of the "bowl", about ½” from the wheel mounting surface, all the way through to the rust belt and the hub circumference, hoping to weaken the bond of the rust. Now liquid wrench is working in these holes. I'll keep you posted of the result.
One of the members used to try jacking the rotors with two long bolts and the caliper bracket that works as nuts. I followed his idea and tried it, but no go, mainly because I came to worry about the strength of the two ears on the knuckle. They don't seem to be designed to take much sideway forces, and if they break off I'm in deep doo-doo. The thread of the bolt is M12x1.75, by the way.
I feel for you, been there myself. Took 3 days to complete a brake job, with 95% of the work being removal of the old rotors. It's REALLY easy after that. 5 stars for your plight.
H
H
Hopefully your wheel bearings and ball joints survive this full fledged lateral assault. smile
stock CD on LS, cass on LX
4 wheel discs on LX only
Which bolt is that?
sylin Offline OP
Which bolt is that?
The caliper bracket mounting bolt.
1
1
When you're finally ready to put new rotors on, make sure you use some antiseize on the surface where the rotor contact the hub. It works very good at keep it from seizing up on you again.
UBRF.org , Western New York's Premiere Automotive Forum.
Yeah, I got some bolt-ons.
Car Pics
Video of Brullen cat-back on a \'95 SE
How-to: Short Shifter for Pre-98 MTX
"heres the deal $2 grand buy in winner gets the cash and the girl and the respect. We'll race from 0 to Inf. until I win." - someone on the internet
F
F
here in the great white even if the snow not on the roads. Salt
I've learned the hard way to remove brakeparts and apply anti-seize.
I haint rust
Paul
