Posts: 16 |
Anyone know if the Taurus SHO motor/tranny will fit under the hood of a Contour? I'm not happy with the stock 170hp for the Contour Sport 2.5L Duratec and would love some extra power!
Marc
'98 Dark Blue Metallic Contour Sport "SE"
2.5L Duratec V6
Automatic
Posts: 6,760 |
Um, have you searched? (I hate beign a search nazi).
Anything can be done with money. First...can you afford to buy a 3.4L V8? Um, probably not, they still cost quite a bit from a junkyard. Second, can you afford the fabrication to put one in?
The easy answer. NO!!
The SHO V6 will not fit either...
Ryan
Trollin!
Posts: 3 |
I wouldn't touch a V8 SHO engine with a 10ft pole... They have serious cam problems that destory the engines... I know...I had a 96 V8 SHO that decided to grenade on me at idle  also finding one of thoes engines is a needle in a haystack because of this specific problem...you'll pay for it...I've heard of USED V8 SHO engines needing slight rebuilds for 5-7k
Matt H.
90 Saleen Replica w/N2O 300rwhp/390ftlbs
98 Ford Explorer 5.0 to run civic's over with
96 Contour GL Zetec (Wifes Car)
Posts: 6,760 |
Yes, but there is a fix out there for them, $500 to get the cams welded or $5k in a 'used' engine...
Ryan
Trollin!
Posts: 4,294 |
then make it a 3.0L and then add a turbo or super charger!
95 SES Sold
99 SE Sport Sold
99 SVT T-Red Tan Interior. K&N, Magnecors, 19' Theorys, And some audio stuff.
Posts: 5,975 |
Posts: 7,025 |
Originally posted by SVT ST PETE: SEARCH
exactly, this has been beaten to death.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,355 |
i thought you could remove the rear seats and and place it mid-engine and turn the tour into rwd...
--Chris--
1999 Silver Frost SVT
#1671 of #2760
Posts: 2,676 |
Look at my sig, a guy in Canada put a V8 SHO block in his 92 Topaz, but it took a lot of modding to get it to fit. I would assume that you could put a SHO in a 'tour but the time and money could be better spent elsewhere.
Posts: 6,760 |
No he didn't. He put the V6 SHO motor in his car. Olympic is his name over at shoforum.com
Ryan
Trollin!
