#788865 11/05/03 01:45 AM
boy1 Offline OP
i just installed a new HU into my 98 contour, now whenever i turn left the sound cuts out. has anyone had this same problem.(it ciuld be the cheap HU). i don't know for sure.
#788866 11/05/03 03:53 AM
what kind of head unit did u install? did you use a wiring harness? is it when you turn left or just when you signal left?
blue 95 se MTX alpine 9805 2 diamond 12" cm3's tuned to 38 hz 4 pioneer 3-ways(POS) jbl bp1200.1 pimpin hoes, like the river flows..... constantly!
#788867 11/25/03 06:14 PM
boy1 Offline OP
it is called Dual x108, installed it with proper plugs,and it is when i turn left or turn the wheel that way. I found that the cold weather could be part of the problem, but i don't think its that. i installed a wiring harness and everything. that is fine. i don't know what the problem is.
#788868 11/26/03 12:56 AM
boy1 Offline OP
i don't think that it is the wiring in the doors, because the hu still has power and is still func. its now when i drive and turn the wheel that the stereo goes out, there is somtimes a cracking noise that comes out of the speakers. about a week ago the whole thing was fine, until a snow storm came. the next moring it worked fine, but then the next day the same thing started happening again. i checked all the connections, i'm sure the wiring harness is fine. i just don't know what to do.
Moderated by  dnewma04_dup1
