#66896 07/23/02 03:39 AM
skon Offline OP
I have a 96 tour atx with 78000 miles. At about 45 mph I get a ticking from the right front side of my car. It only does it over 45 mph and it will sometimes be loud and at others very faint. I had a car pull up along side, and it was very loud. Any Ideas? The closest thing I can say it sounds like is a rock in the tire tread but there are none. Thanks for any help.
#66897 07/23/02 05:03 AM
E
E Offline
E
mine used to do the same thing but it went away. someone at work suggested that it might be one of my brake pads moving slightly in the caliper, back and forth hitting it therefore making that ticking sound. don't know if that's your problem but it worth checking out.
95 Contour GL Zetec
New 16" Focus wheels! (look better on contours!)
APC Plasma white high and low beams w/ upgraded wiring harness
Pilot Hyper white fog lights
Cold air intake
Optima battery
APC billet antenna
Sony Cd Player w/ jensen subs
Green neon pedals
Green strobes for reverse lights
Ventvisors
20% mirror tint all around
Custom grille
Aftermarket keyless entry
Remote car starter (very usefull)
#66898 07/23/02 06:10 AM
well...when i start my car @idle..the crank belt hits the crank casing...but it moves back into place after a couple miles of driving
Teal|'95 'Tour GL|75k|
16V 2.0|Rebuilt ATX|
Factory Euro Mod's (Ordered in Dec '94 From Holland)-|Larger Radiator, Oil pan, Fan, Tank..little things make a difference|
Mods to Come-|Open air w/K&N filter|New Exhaust|Pre-98 Bumper|Trim Kit|Fox 2 Rims|& More..|
#66899 07/23/02 06:24 AM
F
F
Sometimes when I'm driving at high RPMs for an extended period, I too hear kind of a faint ticking/pinging sound. What I did was I started using higher octane gas, and they went away. Just my 2 cents smile
