If the pads are knocking, they must be moving in the calipers. If they are moving in the calipers, they must not fit properly. This is not uncommon with some less expensive brake pads.
With the wheels off, check to see if the pads can be rocked slightly forward and back. If they can, they are too loose. You may be able to get a tighter fit by removing the pad and expanding the backing plate by dimpling it several times with a center punch near the ends. If not, you will need to replace the pads with some that fit better.
