#783415 10/28/03 07:00 PM
Check Engine Light came on for the first time at 72,000 miles yesterday. I took it to Autozone to get the code read for free (learn about that one here) and they said it was a P0430. From searching the forum it looks like an emissions thing, I thought so b/c driveablity was not impacted at all, something about cat efficiency some posts seem to point to the cat and others to the O2 sensors. So here are my questions:
1. The Light came on during a torrental downpour here in CT, could moist air have anything to do with it?
2. Which 02 sensor(s) should I look to replace and what order, I think I rather start with the O2s they're cheaper than a Cat.
3. I read in one post the cats are covered by warranty upto 8year/80K miles, does that include second owners?
Right now I have the battery disconnected to clear the code on the outside chance it was a fluke but if/when it comes back I want to know where to start. Thanks.
Mark
#783416 10/28/03 08:48 PM
Plenty of info if you do a search of the archives.
P0430 is bank 2 pre-cat efficiency below threshold. Simply put, the signals of the pre-cat and post-cat sensors are compared in order to imply proper catalyst operation. If the cat is really bad, the manifold/precat is covered under the 8/80 emissions control warranty. A way to verify is to swap the bank 1 and bank 2 post-cat sensors. If the code changes to a P0420 (bank 1 precat) then you know the sensor is bad. If it stays as a P0430 you need to get it replaced.
AL
Red '98 SVT E0 3098/6535 DMD other stuff and a Bullitt fuel door
#783417 10/28/03 10:07 PM
N
N
does your CEL go on and off?
I've been told (and did myself)that it's better to change both O2 sensors (how many are there?)
#783418 10/28/03 10:44 PM
The CEL was on continously until I disconnected the battery to clear the code. I driven 50 miles since then (mixed highway, traffic, country road) and it has not come back on. I forgot to give my cars essentials earlier - it is a '99 Contour with the Duratec V6.
Mark
#783419 10/28/03 11:12 PM
P0420 and P0430 codes indicate that the downstream sensors are working and doing their job. If there were a problem with the sensors not switching a different code would come up. The downstream sensors are not subjected to the abuse of the upstream sensors and should last 150,000 - 250,000 miles.
A failure of the ECU to control mixture properly can in some instances load the pre-cat up and cause a false reading from the downstream sensors. You may also experience the rotten egg smell from this. If this is the case the A/F problem should be corrected as this will shorten the life of the cats.
The only accepted way to diagnose cat failure is to have an emmissions test. Ford will usually charge for this before agreeing to warranty work.
