Over the past year or so, I have received misfires only upon starting the car. I never get a misfire once the car is started.
Here are the dates and cylinders affected:
04/20/2002 Replaced original spark plugs w/ Autolite APP764 (double platinum) 09/02/2002 Replaced original ignition wires with FMS wires 10/05/2002 Cylinder #5 (P0305) 05/03/2003 Cylinder #2 (P0302) 06/29/2003 Cylinder #3 (P0303) 09/16/2003 Cylinder #3 (P0303) 10/14/2003 Cylinder #4 (P0304)
As you can see, a misfire only happens every few months and they seem to affect random cylinders.
FYI: The gaps on the plugs should be good. I used dielectric on the ignition wire boots.
My guess is that either the coil is going bad or the FMS wires need to be replaced.
Any intuitive guesses out there?
96 Contour SE
Duratec V6 24-valve 2.5L ATX
108,000 mi.
Replaced: crankshaft w/ DMD, EGR valve (clogged), EVR, DPFE, PCV valve, evap emissions hose & tube (cracked), window regulator (broken), LH & RH PCV tubes, UIM gasket (leak), ignition coil
