javi718 Offline OP
I need to find the thermostat on my 98 2.5 but I just cant seem to find it, if anybody knows where it is help me out. aight thanks
It is in it's own little housing away from the engine in the radiator hose on the left side of the engine behind the battery and below the air intake tube. It kind of looks like the hose has an aluminum swollen spot in it. The housing splits apart by removing the thru bolts.
Right side of the engine as you're looking at it from the front. 2 bolts and it's out. Pretty simple.
Change the O-ring while you are at it!
Dan B. 96 SE 2.5 auto
