Robina Offline OP
I went to Ford Yesterday for a recall on the switch for the air conditioning heater. Once they put it in they said my air would still not work that it was a heater blower motor and it would be 128.00. After spending 700.00 for a water pump forget this. I went to Rapid Motor parts and got the part for 47.00. Is it hard to put in. The mechanic left the piece hanging down on the passenger side. My husband is no mechanice but any help would help us, this car is so bad. Thanks
Hope this helps...
«1998 Contour/Mystique Table of Contents»
«Group 4: Electrical»
«Section 412-02: HEATING/DEFROSTING»
«REMOVAL AND INSTALLATION»
Blower Motor
Removal
1. Remove the pushpins for the upper footwell trim panel on the passenger's side and remove it.
2. Remove the blower motor.
1 Disconnect the electrical connector.
2 Lift the securing tab slightly.
- Turn the blower motor approx. 30º counterclockwise and remove it.
Installation
Note:
Engage the securing tab for the blower motor.
1. To install, reverse the removal procedure.
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
