#66585 07/19/02 01:03 PM
bigsam Offline OP
I keep getting the CEL and the code is po171 lean bank one i checked everything from vacume lines to O2 sensors, and so on from when everyone told me to check. but this mite help more. when i reset the CEL (by removing the negative side of the battery) and the light go's off but comes back on a day or so down the road with the same code (p0171) i just saw what i am doing when it comes on.. I'll be riding down the road and everything is fine but if i need to pass a car or go up a hill and i press the gas peddle the light came on.
Does anyone have any idea(s) what this mite be? any help would be fantastic i am getting sick of seeing the CEL thanks
Sam
1996 Contour GL Zetech no add on's just stock a plan jan lol
#66586 07/19/02 05:43 PM
I'd replace the plugs and wires first, especialy if they are due. Sound like the light is comming on when you push the car harder.
hunter green 96 mystique mtx, sabb side markers deep tints
car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control
Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
#66587 07/19/02 07:20 PM
bigsam Offline OP
Been there done that with the plugs and wires
#66588 07/22/02 01:15 PM
bigsam Offline OP
Terry maybe you can help with this it is driving me nuts with this CEL thanks
Sam mad mad mad confused confused
#66589 07/22/02 03:29 PM
E
E
Have the TPSensor and MAF checked. The only reason I say this is because this is what happened to me: Going up a hill - CEL, try to pass someone - car boggs down and doesn't want to go anywhere - CEL.
'95 Contour GL, zetec mtx, drop in K&N, exhaust res removed, 4 10" Kenwoods powered by 1000W Visonik amp, 4 5"x7"/6"x8" Visoniks
"Buy American or apply for Japanese welfare."
www.geocities.com/fordcontour05/contour.html
#66590 07/23/02 12:18 PM
bigsam Offline OP
Escort1991
Member # 4428 posted July 22, 2002 11:29 AM
When this happend to you what CEL code did you get? mine is p0171 lean bank #1 and what is the TP Sensor?
