I run the firm behind Thomas Knight's new website (launches Dec. 1st) and advertising campaign, and noticed that this site has been sending traffic to
www.boosthead.com. I just sent Geoff your URL, and he should be logging on soon to answer all your questions, but in the meantime I can help you out a little.
We have found a way to cut our production costs substantially, so now the ESC blower is $1995, not $2995. Because this is a universal unit designed for most engines under 3.5L, you will have to purchase additional components, the cost for which ranges from $500 to $1000. $3K is the average total investment.
If there is already a quality turbo or SC kit available for your model, it might be more practical to buy one of those. However, keep in mind that the ESC produces instant boost, and furthermore is powered by an independent system, so you can make huge gains with zero parasitic loss. Check out our most recent dyno runs at
www.boosthead.com/dyno.htm. Geoff switched the ESC on at 5,000 RPM and the boost went through the roof!
A common reaction to the cost of the ESC is "why should I spend $2K for instant power when a Nitrous kit costs only $600!" True, the kit may only cost $600, but here in Miami, NOS bottles cost $30-$45 per refill, and most of our serious customers go through 2-4 bottles per week. Do the math: that's anywhere from $3120 to $9360 a year just in Nitrous, plus the hassle of going to get it refilled.
In contrast, with a properly installed 200-AMP alternator upgrade and Odyssey-type batteries, the power source for the ESC can be replenished in 5-10 minutes of driving at zero additional cost. It's pretty obvious where the savings are when you look at the big picture.
Hope that helped. Geoff should drop by soon.
Regards,
David J.
