Yeah!
I also learn a lot about starting from that,
such as hot wire it you said, and finally
almost become a start expert.
For my car, I can find that Diode from the
the fuse box whose size is like a fuse.
At first I cannot get it. When I have located
all fuses and relays according Haynes Manual,
I feel the remaining one have to be the Damned
Diode,even it is not labelled on it.
If you still cannot find it, just Hot Wire it
as you did. Now I have known how the starter
and starter solonoid work together to crank
the engine. Just connect the "+" of battery to
the suitable head of the starter,it works!
I think maybe it is FORD's new anti-theft function. Now nobody can get your car run
even if you give him the key. Only you can
get it move.
Contour 95, GL, V6, ATX
