#66268 07/15/02 06:52 PM
Popeye Offline OP
I recently had a my water pump replaced. The temperature now seem to low. My tempurature guage reads on the N in normal. My thermostat was also replaced. Is this a problem?
'98 Mystique LS
Duratec, 5sp
Pacific Green
Custom Single Exhaust (no resonator and one turbo muffler)
#66269 07/15/02 07:00 PM
E
E
I wouldnt worry about it. The thermostats are different and they read different. If it works it will be fine.
'95 Contour GL, zetec mtx, drop in K&N, exhaust res removed, 4 10" Kenwoods powered by 1000W Visonik amp, 4 5"x7"/6"x8" Visoniks
"Buy American or apply for Japanese welfare."
www.geocities.com/fordcontour05/contour.html
#66270 07/16/02 04:28 AM
H
H
It raises the question as to whether or not proper temp thermostat was installed. I would guess that tolerances between 'stats of same temp rating should be within the width of one letter on the gauge.
stock CD on LS, cass on LX
4 wheel discs on LX only
#66271 07/22/02 01:13 AM
When I lost my pump I wasn't able to get a new thermostat at the time I replaced it and after that I had a problem like yours. It would take the needle a while to actually get up to the "N" and then it really wouldn't go any higher unless I was idling for a long time in hot weather. What happened is that my thermostat had been damaged by the abnormally high coolant temp when the pump broke. The thermostat had failed in the open position and coolant was always circulating throughout the whole system even when it didn't need to.
How sure are you that the thermostat was actually replaced?
#66272 07/22/02 01:21 AM
One thing I noticed about the temp gauge in our cars.
Last summer, it never read above the N. I changed the t-stat out when I changed the w/pump around November. All winter then the gauge read around RM. Fine. Then, it the spring, when the weather started to warm up again, the temp started to drop again. All this summer, it has never read above O.
Weird.
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course."
#9 - Hitting .400 for ever
"Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez
"The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
#66273 07/22/02 01:29 AM
I put in a new Ford Motocraft themostat after having tried an aftermaket one..temp reads at the N mark which i think is a lot better than resting up over the L.Pump impeller is also new.
stock 95 LX,6cyl ATX
#66274 07/22/02 03:51 AM
my car would run high before the water pump and thermo change in feb....here its usually 90-100+ all summer long and for the most part my car runs right at the 'o' in normal....i also think it has something to do with the filter but i dont know for sure
at any rate im glad it runs cooler and it was running a yr ago...and it is running cooler somewhat during summer than it was during winter
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
#66275 07/22/02 12:30 PM
Mine's always read in the "N", before and after the WP went.
#66276 07/22/02 10:56 PM
Question:
I have over 120,000miles on my Contour and have never had a problem with my waterpump(knock on wood). What's different about my pump than all the pumps that went bad? Were there different batches and only certain problem years?
Thanks,
Rob
95 Contour LX
Approximately 120,000miles
2.5 MTX
Red
#66277 07/22/02 11:48 PM
I just had mine replaced for the first time @ 215,000km, i had it replaced because it was leaking. It wasn't a noticeable leak but i was doing other work on the car and the mechanic offered to do it for no extra charge, i couldnt say no.
The impeler was still in good shape, maybe there was different batches and only certain problem years.
95 SE MTX Midnight Red
Dual Extrude Honed SVT Intake Manifold / 65mm TB / SC Cold Air Induction / Ford Racing 9mm Plug Wires / Quaife Limited Slip Differential / Centerforce Dual Friction Clutch / Fidanza Flywheel / UR Underdrive Pulley / Custom Dual Straight Flow Exhaust / StreetGlow Sport Pedals / Tint / Pioneer Deck and CD Changer / 2 12" Orion XTR subs / 2 MTX amps(425&280watts) / Phoenix Gold Titanium Bass Cube and Wiring / Boston Acoustic 5x7's, and Rockford Fosgate Tweeters. Next: 19# injectors and chip
Rebuilt engine @180,000 km
Rebuilt tranny @215,000 km
