#773774 10/16/03 10:51 PM
ok i need help w/the quickness please. im trying to replace the fuel pump in my 00 csvt and ive tried searching the forum under fuel pump and replacing fuel pump but havent found anything yet and i really dont have time to. if someone could just tell me how the get the fuel line off the cover of the tank id be straight. the obvious was easy as far as taking off the clip and unplugging the connector. now what am i missing on the other plug??? if someone could give me a link or just tell me how to get it off it'd be much appreciated!!!!!!!!!!!!!!!
CEGers must stick together!!!!!!!!!!!!!!
00 Toreador Red SVT-#1751 of 2150 KKM intake No resonator Eibach springs 2 1/2" drop No door ding guards Side markers
#773775 10/17/03 04:42 AM
Pull the back seat.
Cut the hole larger.
R&R the pump.
RTV a patch piece back on.
Put the seat back in.
#773776 10/17/03 05:00 AM
From the FAQ section.
http://www.contour.org/mods/mods.php?s=howto&displayid=39
PS Don't forget to throw away the filter disc at the bottom of the fuel pump module. Probably the reason that you are changing the pump. You don't need it. There is still a sock type filter inside the pump module.
